Forge motorsport EGR avoid like the plague
I fitted a forge motorsport EGR delete about 2 weeks, i was not happy with the fact the item was of poor quality (flange) and did not include nuts - WTF not include nuts that would likely cost 3p each!, i do not own a garage and it was hard to acquire these nuts.
So i will not buy anything off them again, i gave them 2 weeks to respond and they did not even get back in touch. They clearly DGAF so i dont DGAF about bad mouthing them.
Avoid and buy darkside etc EGR instead.
Edited by ajs_vrs
Screwfix? B&Q? Amazon?
I live out in the sticks and only have this car, besides they should be included and the quality is poor.
I shouldnt have to buy a tub of 50 or 100 nuts when i only need two.
Was it advertised as including nuts?
Pack of 20 shouldn't cost more than a quid or two. Did the description say it included fixings / fastenings? If not, sorry bud, but you were crazy to start the job where you take the engine apart without checking you had everything you needed to put it back together again.
I wish there was instructions or actual contents listings nothing on the box or inside.
Your right i should have checked but i thought something like this should have been included or at least put on your will need.
Nevermind, besides the nuts wasnt my only issue with the kit as explained above.
Edited by ajs_vrs
Send it back and get an Allard kit.
are you not able to use the bolts that was holding the egr on in the first place?
Hello
Im sorry that you have had issues with the EGR pipe.
Please can I ask who you have emailed as we have received no emails about this here in the UK office.
The reason we do not include nuts in this kit is because there are no nuts to include.
You need to use the original nuts from the EGR cooler/exhaust manifold.
If you had phoned us straight away we would have been happy to help you with any problem.
Thanks Kris
I was just thinking I'm sure my Allard EGR delete uses the three original bolts that holds on the EGR unit?
I know darkside comes with 2 new nuts for the blanking plate, which is useful if you round the corners off or drop one like i did
Wont they be the 2 for the blank?
I cant remember I thought they were nuts
Allard kit comes with 3 M6 allen head set screws for the pipe and 2 M8 nuts for the blanking plate (studs on the exhaust manifold) http://www.egrvalve.co.uk/#
Hope this has been sorted
