Double Din Stereo
Hi guys,
Any recommendations on a double din unit? I am looking for;
Cheap
Easy to fit
must have sat nav
How easy is this to install & does it come with eveything needed to plug in and go?
For example conversion cables (if needed)
You'll need a small fascia trim piece that you can get from the dealer for a couple of quid, and an aerial amplifier that you can get off eBay - click here. The standard wiring is by ISO plugs so provided your aftermarket unit hooks up by ISO plugs that part is no problem. You'll need to swap over the yellow and red cables on the stereos wiring - most makers have these on bullets so they're easy to swap. Other than that you'll probably need a file or coarse sandpaper and lots of patience to help get the double din cage to fit because it's a very tight fit, and you'll need to remove the centre vents and be prepared to skin your knuckles as you try to hook all the cabling out of the way to get the stereo to sit flush.
just plug in, slide in any way you go, youll need a double din fascia as said about, and a GPS antenna ( hides behind the dash) and your set to go
Im very interested. Would you accept an offer?
well i originally had it up for £350 so already knocked £100 off pal
id do it cheaper if you were collecting ?
im selling this matey £250 posted
http://www.motorspee...60/product/4638
I doubt you would get a satnav radio any cheaper than that. A very good deal!
Although most people have smart phones these days... Tomtom on my iphone works amazingly in my opinion :).
Thanks.
Will get back to you - Need to see if the girlfriend would go mad before I purchase. Last time i mentioned a £400 unit I was going to buy I was told well get used to the size of the screen as you would be watching a hell lot of it!!!
good job its only £250 ;) £150 left to keep her sweet haha
And the smartphone double din units are quite competitive in price.
