STAGE 2 GARRETT GT1749V HYBRIDTURBO PD 150
Cut a long story short this was on my car and engine failed leading to turbo sucking up debris from engine.
I have just got the Turbo back from AET turbos today after spending £500 to have it repaired the turbo is still in the sealed bag from AET - Therefore you are gettin a brand new turbo which has never been fitted to a car also a 1 year warranty from AET TURBOS
The turbo cost me £1295 and that is still the price from AET today , Bearing in mind i have also just spent £500 on repair the turbo stands me at £1795 !
I am looking for £950 posted to your door ! ( thats a saving of £345 )
As stated above will come with a 12 month warranty from AET
If interested please email [email protected] or mail me on here.
Any Questions please ask
Would this fit my Toledo PD150 Sport?
And if so, what gains or benefits would it offer?
Damo
Damo
Yes it would fit your toledo
it is a GT1749V frame size, the unit has a large trim hi flow compressor wheel and machined out compressor cover to suit Unit has uprated 360 degree motorsport thrust and total seal piston ring seals
Basically the internals are a lot bigger and stronger. And are capable of bigger HP than standard turbos.
The turbo also comes with 1 year warranty with AET turbos
to the top..
Ultimate best price as £950 is steep
Also why did it need rebuilt?
Also is it a va or vb?
I.e 130 or 150 turbo?
says pd150 in the title mate. :-)
Yeah but it just said v
So maybe confusing as va is 130 and vb is 150
Just trying to work out what the turbo came off
If its a pd150 then its a vb.
It is a 150 turbo
On the turbo it says VT073
25760 GT 17
Also needed rebuild due to engine failure and turbo sucking up debris ..
The turbo is brand new now never been fitted to a car
Cheer
Is it clockable?
Need it for a 150 car?
Also what bhp is it rated to? Thanks
25760 GT 17
There should be "49 VB" after the GT 17 bit. Does it look like someone's tampered with the label? Normally etched in to a little plate.
@bigjase What do you mean is it clockable ? ,The turbo is rated up to 240 BHP
@devonutopia here are pictures of the turbo mate
£900 posted !
he means can you spin the turbo housing to face another direction. I know i was able to clock my old VT5 turbo from Allard so the outlet pointed in the right direction for fabia use (rather than Golf mk4 like it came to me) - I suspect this is already "clocked" to point the turbo outlet in the right direction, i.e downwards direction, when fitted.
Ah right yes it's clickable just undo the 8mm bolts and twist it round :)
Ah right yes it's clockable just undo the 8mm bolts and twist it round :)
£850 posted
£850 posted
Please stop. ;)
Rules:- The only discussion permitted in classified threads are those which show interest in replying to the advert. Criticism of items or pricing, chit-chat, bumping threads or any other discussion not relevant will be removed.
Did you bottom out whether this is VA or VB turbo and why it is not on the plate?
Hi Mate,
Its definatly a 150bhp turbo ,
here is a pic of the plaque
ttt
