Help - warning lights
I don't have an owner's manual for my Octavia 1.6 petrol. Can anyone explain the two yellow warning lights (pic attached). Thanks!!
I know the bottom one is something to do with emissions but not sure about the top one.
Engine warning light and traction control light, usually caused by faulty maf sensor
Bottom 1 is engine managment light and top 1 is esp warning light.
Edited by jonesy_04
Thanks guys!
There will be fault codes stored in the ECU. It's quite likely the MAF has died, but I would still advise you get a diagnostic done with VCDS/Vagcom before you start throwing parts at it as there are several other causes of those warning lights to come on.
