Caliper bolts
The one with the ( think it's 7mm allen key) that holds caliper to hub. One of mine is showing signs of thread damage ,and don't want to risk stripping hub
Q1-are they the same on all Fabia mk1.
q2- is this the same item as on a Polo( reason being that local Skoda dealer is crap, but our local VW place is very helpful). f so ,anyone got code .
If it's the rears, then they're the same and it's an 8mm allen/hex key.
If it's the fronts, then no, not the same.
It's the fronts , so it looks like a trip to VAG TPS place then , as I wouldn't trust my Skoda place not to want to tell me that thy don't come except with callipers.
Got it from VAG TPS ,for a front calliper on mine. Bloke behind counter said that they're all much the same throughout the range. I don't have rear callipers ,and the allen key I used has "7MM" stamped on it .
