seen some wheels wondering if theyll fit?
They came off a toyota celica t sport, and are 5x100 pcd
wondering if they will be ok for offset? Could anybody tell me as even if i knew what the offset was i wouldnt understand it, or whether its anygood.
Thanks in advance
Pcd us correct 5x100
Whats offsett and hub size mate?
57.1 i beleve is ours
And offset somewhere around et35 ish
2 secs i shall confirm
Edited by Lloyd55vrs
Yep 57.1cm bud
i dont have a clue dude, ill see if i can find anything
is 57.1 the offset? if so would a greater number mean further out or in from the arch. as you can see im crap when it comes to this
they are a 6.5j? i think, is that of any use????
Ive found older toyotas to be 54.1mm from a lil nose mate :(
Yep 57.1cm bud
That'll be 57.1 mm then.....imagine wheels with a centre bore of over half a metre :rofl:
57.1mm is the hub size. Larger than that and you risk having uncentered wheels and obviously loose.. Smaller than that and you have to mill it out or lathe it out slightly to get it to fit on your hub.
Offset is the amount that it protrudes from the hub. So if it's less, then it goes further into the wheel arch (and subsequently closer to the strut).
The J measurement is in inches of how wide the wheel is. Obviously wider means that it is likely to sit further in your arches unless the offset is larger (or you have spacers), and you'll need wider rubber on them (or stretch).
And you know pcd already. ;)
Hmmm ? H&R do adaptors and list pcd as 114.3 and hub 60.1
So must be various toyata rims :(
I'll keep nosing bud but seems im becoming a useless jellyfish
Sorry bud, but i'll keep a nose in google
Ha ha yeah thats what i mean mm :D
Slip of the thumb
ah the light is slightly brighter cheers, so it looks like these are way off then really. back to searching for wheels.
Thanks for the help everyone, ill stick to vag origin 5x100's
Edited by Lofty79
Offset will be the et??
57.1 is the hub hole of the rim
5x100 is the bolt patrern mate
Yeah :D
Man i may be drunk lol
If in doubt matey :)
Still on a hunt for rims r u bud?
Do you have a budget ? Or still thinking wheel piracy :)
Notice i didnt say "rim" lol brain mouth filter ;) still working haha
yes, hunting for change, 17's they must be, i have tyres in abundance and want some nicer looking rims, ive seen many rim sets around £50-£60 and usually eventually get what i want so ill keep looking
Edited by Lofty79
If i see any cheap sets bud i'll give u a pm :)
cool, cheers, i seen some green ones on here at one point, cant remember if they were £60 or not :giggle:
:D te he
Seen these on ebay mate
Number
221142785374
Scratch that ... Foooked :(
shame they looked good. Thanks anyway though
use 30mm spacers ?
Yeah seen and thought oo oo
They looked at pics :(
Gun jumped :( arse
