Retrofitting maxidot
I dont think i have the full maxidot on my car , i can toggle things like oil temp , fuel consumption etc etc but dont get the full menu
Is it possible to retrofit the module??
Maxidot in the Fabia compared to the Octy/Superb is cut down quite a lot.
You can't change settings like full/single unlock etc.
If you have a vRS, then you have maxidot as it is on the Fabia.
you can hold down button that you use to select left or right (say right for 3 sec) which gives you a wee menu but as stated above nothing like the octy
Thanks a lot , I didnt know about the 3 sec thing dont know how I missed it as i mustve read the manual half a dozen times
Probably want in the manual I read the maxi dot pages hundreds of time trying to figure out a few bits and pieces, i ended up fiddling with buttons until i figured it out :S
Didnt even read it ma dads got octavia so guessed it was something like that and it worked
