Pressure Drop
Driving along on Friday night, on my way to the supermarket, when the engine warning light came on but it didn't go into limp mode.
Phoned the dealers who hooked it up to the diagnostics, came back with a coupl eof errors, think they were 17103 & 17104, one of them indicating a pressure drop in the Turbo system and the other one not in the book.
Glad its under warranty but conderned that its a Y reg vRS with only 29k on the clock and there could be a potential turbo replacement.
Anyone else had this typ eo fproblem or know what the other error code is?
How can a Y reg still be under warranty? :confused:
Are all your boost hoses intact?
Dump valve IIRC
Nick, maybe an extended warranty through a dealer / insurance?
Not 100% that the codes are correct, doing them from memory, but they were in sequence.
I bought it 2nd hand from the dealer so its Skoda used warranty
Have drop the car off at the dealers for repairs this morning, and have got the correct error codes..............17705 & 17704, does anyone know what they are?
From the thread name I was going to say 17705, I have it and it was the DV (but theres a couple of other things it also could be). Do a search here as it
The search button is your friend http://www.briskoda.net/forums/search.php?searchid=817741
Try searching for "error code 17704"
I had a lot of trouble with this code. It relates to the coolant system - probably the thermostat, or possibly the water pump. I had both replaced under warranty, along with expansion bottle and coolant level sensor on my old Octy. Since then, the engine temp sender has been replaced also.
I didn't have the 17705 code, but from what GAFF said above, try the DV.
