fitting Jom Coilovers
Thought id just put this all down so it might help some people on here as they are quite a common choice for the fabia MK1
Alot of the information I have had to find from several different threads:
Fronts
Top mounts - Good idea to change these while the front shocks are off
Bearings - same as above
Mondeo drop links ( seems to be abit of confusion on here as to whether they are the MK1 or MK2 ones? )
Rear
Ibiza cupra bump stops part no 6q 051 2131 d ( these are shorter that the original ones on the rear, they stop the car riding on the bump stops if you go quite low )
Some people choose to cut and modify the existing ones.
New nuts and bolts ( only a few quid so why not! )
copper grease to stop threads siezing on the shock adjusters
Locktight for the nuts
You will need to get the wheel alignment done after fitting as it will change the camber etc.
I got my top mounts and bearing from vwspares
Top mount for sports suspension part number 22930 ( there are two listed, standard and sports... both the same apparantly the sports one is stiffer plastic
Mount Bearing part number 1006410003
I also got the suspension bolts from here
You could replace the rear top mounts but as they are quite easy to remove the rear shocks I decided not to at this time.
Maybe a good idea to replace any bushes that might need doing ie. console, anti roll bar
Also ball joints or track rod ends etc as you will be getting the car re aligned afterwards.
Tool for seperating the hub to get the strut loose ( some people use an allen key or a screwdriver socket )
Some people buy adjustable drop links which in my opinion are quite expensive when the mondeo ones will do the same job and pretty pointless unless your planning on changing the ride hight all the time.
Ideally budget about £130 for all of the above with the wheel alignment etc
If ive missed anything please feel free to advise
Can anyone clear up the mondeo drop link issue ( mk1 or Mk2 )
Mondeo drop links mk1 or mk2 anyone?
ford puma are the same also
Nice one, that will be why some people say mk1 and some say mk2
