120LS to 130LR/H Spanish Performance
Look forward to seeing the photos :)
That sounds like the ratios from the old work's close-ratio gearboxes. I wonder if any of those still exist?
Hi friends
I bought a motor "136M" Skoda Felicia a 1.3mpi to transform a carbureted engine. Some parts need to be changed but it is a good engine with 34000km.
I'll use a carburetor SOLEX 32-36, 40 weber not want to use because it is not necessary for regularity rallies.
It wasted too much gasoline.
The 136 engine is finished! Next saturday will be running onboard!
Nice : keep posting updates Sergio! :)
  • 6 months later...
  • 2 months later...
Good luck with this. The car looks great :)
Hi guys
During 4 year I was looking for a S110r coupe for built a 130RS unit. S110r was a very rare car in Spain, and I think that no more than 20 car were sold on 70´s.
The car was in very bad conditions than 22year abandoned on a barn, but the chassis was well. There aren´t documents since 1992.
Now, we want "make up" a bit for pass the MOT and take again the documents as 110r coupe, before start a build de 130RS.
Only necessary works for get the MOT.
Engine worked with a new battery and a few of gasoline. The water pump was KO, the turbine was dissapeared. A new wheels and the exterior "make up"
Some days ago, my father (I can´t because my health is not good last months) started clean the cockpit. A lot of kilograms of barn dust were there
Brake and clutch pumps looks good.
Seats and carpet......KO
Make up
Front lights are working good, but rear ones....... were KO
This area was KO too. He removed old skay and foam, and painted it.
Hmmmmm these are very rare now and it might be worth saving. You say it runs (the engine) but i am worried about the body. Those panels at the back look bad. However the bottom looks very good. Have you bought this car?
Sorry to hear about your health :(
really, the engine work well after 20 years shut down. At first time, without gasoline not work. At second time, almost. At three time, with a new batery and more gasoline, turn on well
Yes Sergio it sounds fine!
GREATEST JOB, I hope to see the car soon
