Bluetooth Fitted - minor VCDS coding query
It took me 3 hours (some bits were extremely easy whilst others had me baffled for a while) but at last I have Bluetooth installed, all works fine - Maxidot showed the phone options even without any coding can make/receive calls/phonebook displays (all with an iPhone I hasten to add).
Initially I had a plethora of fault codes but after clearing these and having a run out all left bar 2 (suspect it was having the battery disconnected).
One was that the CAN Gateway had not been correctly coded - sorted by adding Module 77 to the installed list, the other that I can't get to go away is the below:
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663009948
Coding: 0A01000000010101
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_SK35.rod
VCID: 397991B8B88BA3D026B
1 Fault Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 11
Mileage: 277 km
Date: 2000.14.26
Time: 14:50:04
Any ideas?
PS my CAN Gateway now seems to make a bit of a noise when being accessed, I doubt this is normal but is it or do I need to see what seems to have disturbed it?
Don't worry about the gateway, i'm sure it is ok
Change the coding on the bluetooth
0A01000000010110
try that to see if it clears the fault
0A01000000010110
Superstar, seems to have cleared it. One IMT beer token is yours!
  • 9 months later...
0A01000000010110
Eddie you seem to be the vcds god. I am a numpty. I have a new vcds  and it was perfect. Just fitted bluetooth and now the port seems not to communicate with anything all modules are red I also got it to work once and  it  I had 77 on my list in vcs how do I get to the can etc to program it.
Is there a reference for how to code retro bluetooth anywhere please.
Sorry for being such a dumb *****
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 11
Mileage: 277 km
Date: 2000.14.26
Time: 14:50:04
Any ideas?
How did you fit the adaptor behind the bolero mine won't go back in?
Got it working to scan error codes below if you can help then would be so happy please
19 - Can gateway
77 Telephone
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603527251
   Coding: 020004000100111100000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_SK35.rod
   VCID: 234E9A832AEB45001D9
3 Faults Found:
9457171 - Positive output audio channel for speech/telephone
          B104E 13 [008] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 203
                    Mileage: 51610 km
                    Date: 2038.14.11
                    Time: 14:50:04
9458451 - Cellular Antenna
          B1053 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 51610 km
                    Date: 2038.14.11
                    Time: 14:12:28
13636352 - Control Module Not Coded
          U1013 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 51610 km
                    Date: 2038.14.11
                    Time: 14:12:28
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K10407081D
   Coding: E9A07F06000202002303
   Shop #: WSC 73430 790 00999
   VCID: 69D2C8AB40475F50975
3 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 51610 km
                    Time Indication: 0
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 7
                    Reset counter: 203
                    Mileage: 51610 km
                    Time Indication: 0
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 203
                    Mileage: 51610 km
                    Time Indication: 0
Does anyone with this get song names in the bolero? I have all working but no song names from my iphone.
Cannot get the adapter to fit in the head unit area and close so will have to cut and put push connectors on.
The adaptor has to go to the left of the venting.
I had song titles from my iPhone on my unit. But since then with android. Nexus 4 and s4 I just get BT audio on screen.
I have cut cables as fed up with trying to get it to fit. Also lots of the wires are not needed.
