Antifreeze
A quick question. Is VAG G12+ antifreeze the same as other pink OAT antifreezes, i.e. can they be mixed safely? I have 1/2 a gallon of Unipart Super OAT and want to know if I can use it to refill my 1.9D Felicia engine which has always been run with G12+.
Hi,
Can't confirm 100% in your case but I've just bought a couple of litres from Halfrauds for topping up the Felly. It's compliant to TL774D (Skoda) & in my case is mixable. Definitely worth verifying though as I'm aware some do have adverse reactions when mixed. :happy:
I can't confirm 100% either, but I have seen non-VAG OAT that has a VAG G12+(+) standard marking on the pack.
Thanks guys.
Sounds promising, given the details you've been able to provide.
