TDI boost pressures?
What sort of pressures to TDI turbo's go to - I'm aware they never vacuum as they just DON'T ;) but what's the max PSI usually? Isn't it quite high? in the region of 40 PSI, compared to 1.8T 15 PSI(ish)
standard boost is 1.5bar
remapped is 1.55/1.6bar
edit: not sure wot that is in psi money :D
1 bar roughly = 14 psi. So 1.5 ~= 21, 1.6 ~= 22.4
Yes 1.6 bar here too in remapped form.
And 1.7 for a certain froggy owners car :rofl:
oooooooh. ;)
I'm currently trying to plumb my boost gauge in.
Once I've got it in I'll do a write-up and photos thingy.
Yes please. :)
Hmm does can vagcom measure boost electronically or is it a plumbed-in-guage only option? ;)
I'm willing to testify at brunters :D
VAG COM should give you a reading of what the ECU sees from the pressure sensor.
Thought that was for the PD150/PD160?
Thought PD130 went to 1.4bar for revo?
PD 130 goes up to 1.3-1.4 std.
