Which battery for year 2000 Octavia TDI
What specification battery do I require for my Octavia 1.9TDI.
It's getting a bit slow to start on these cold mornings!
I looked online and they recommend batterys with a lower CCA than currently fitted?
Thanks.
Your local motor factor would be the first place!
Or www.eurocarparts.com
I looked on euro's web page and it suggested a battery with ;
65 Ah
540 CCA
but the current battery is 700 CCA, would the above be suffient?
Thanks.
It must be at least 70Amps capacity.
CCA -cold cranking amps is relevant but not so much,a good bat is balanced between capacity and CCA,so if you choose a good brand at least 70amps capacity,the CCA will be sufficient
as above, but if the space takes takes more, give it more, i fitted a 100amp in mine, and it has great cca, had to modify tray, but turns the engine with great ferocity. Everything just seems to work that bit better too
I got my last battery, a Bosch one from EuroCarParts. I did it my measurement to ensure it would fit.
The one I fitted was 444770057 / Bosch BatteryS4 Battery 005 4 Year Guarantee which I picked up with the 25% Briskoda discount
Do you have a TPS near you? Bought a new battery from them from the Leon and they were cheaper than ECP even with the 25% Briskoda discount.
