Misfire Counter..
I don't suppose anyone knows anything about the misfire counter on VCDS my TFSI idles very bad and on group 16 cylinder 4 misfired 69 times in 1 minute. I swapped the coil pack over with number 1 but still misfiring on 4. Also had new plugs 15K ago. Thanks for any input.
Sent from my LT26i using Tapatalk 2
I have seen this on a seat with the engine and it wasn't a missfire but an air leak from the front of the cam cover were the breather pipes are. hope this helps
Thanks mate, ive already started to look for leaks. Ive checked the PCV breather and the EVAP so far no luck. The problem is it's far too cold to be messing around with it lol ill carry on tests if we get a day above 8-10
