Paint Colour Code
Where do I find the paint colour code for my Yeti?
I assume it is on a label somewhere but having looked under the bonnet and in all the door closures I cannot find it.
Have a look under the carpet in the boot.
Mine has a label stuck in there.
I've no idea which bit is the paint code though
In your service schedule book, at the front there will be a sticker with a load of letters and numbers.
IIRC the second line down, and last code should have a number, letter, number, letter - 9P9P/B4B4 (Candy White for example).
Hope that helps.
Or have a look on here http://igorweb.org/equidec/default.aspx
Edited by Preston_Motors
Hope that helps.
Or have a look on here http://igorweb.org/e...ec/default.aspx
I found the label in the front of my service book but there does not appear to be a paint code
It was quite interesting decoding all the entries in that website you listed though.
I also looked under the boot floor but no label there.
Apologies, it's not the far left it's the 3rd code along, second line down 0H0H (Bronze?)
Thanks for that.
The colour is Terracotta Orange Metallic. As I am in Cyprus I am not sure if this is also a UK colour.
That's called Bronze here. I had to find this code myself when I had to have a key scratch taken out. It is on a label under the carpet in the boot as well, as previously mentioned.
0H0H is Bronze (UK spec) so I would have thought it is as near as damn it.
At least you know where the colour code is - and what options you've got.
Glad to help.
Neither zeroHzeroH nor OHOH are recognised when I try igorweb, nor my own 1M1M (which should be Muscovado). Strange, because when I did the other codes recently (http://www.briskoda.net/forums/topic/257655-vehicle-codes/) there was no problem - but I didn't try the non-grid codes at the time.
It makes much more sense to call it Bronze. Because the official Skoda name here is Terracotta Orange, the Logbook for the car shows the colour as "orange". It looks bronze to me!
