Octy Vrs dash
How hard is it to remove the dash out an octy ! Any steps but step
Any help thanxs
Do you mean the whole dash? or just the instrument cluster??
Instrument cluster has 2 torx screws under plastic covers at the top and ('kin tight) clips at the bottom. Cluster then has 2 torx screws again at the top and two 'push in' lugs at the bottom. The hardest bit i found on removal was disconnecting the plugs as the loom was very short.
The main dash is a case of removing trims etc as you go along looking for all the screws they've hidden to hold it on :rofl:
What's the reason as to why to wish to remove your dash-board ?
Very easy can be done in 1 hour
I got some heated seat loom out of a l&k and couldn't get to it all and I was running out of time so I cut what I culd get but want go back and finish the job,
