LED Boot Lights
Would they also fit the door puddle lights?
Are they just a straight swop for the regular boot bulbs, I really could do with more light in there in the winter. Was thinking of adding an LED strip light to the "fixed" bit of the cover.
I have these...
http://www.superskoda.com/Skoda/OCTAVIA-II/Octavia-II-MEGA-powered-LED-dome-light-for-your-trunk
Plug and play, and so much better than the candles that are the stock ones.
They also do LED conversion kits for the interior lights...
http://www.superskoda.com/Skoda/OCTAVIA-II/Octavia-II-04-12-FULL-frontrear-led-dome-light-kit-KI-R
Again, a gret improvement on the stock bulbs.
The only very minor problem with these is that the map reading lights stay extremely dimly lit when the car is locked.
Not an issue as they draw virtually no current in this state, so no worries about flat battery unless its left for months :)
Those look fantastic CFB, 30 euros is pretty steep though!
I thought that too.
After spending roughly the same amount looking for a cheaper alternative, I wish I had just done these in the first place,
Not least for the fact they fit with no fuss. :)
Hi has anyone got any pictures of the led boot light working thanks.
Yes (the 4 LED one above fits anyway)
Yes straight swap.
The pics on superskoda are an accurate representation. They really do make that kind of difference.
I have these...
In sure i read about a solution for the 'dimming when locked' problem somewhere here on briskoda..
Sent from my iPad using Tapatalk HD
Yes and the outer pair on the interior lights. LEDs in the puddle lights make quite a difference, especially if you replace the ones on the inside of the door too.
The only issue I had in replacing the puddle lights was unscrewing one of the screws......ended up buying a flexible screwdriver for the job..
