no interior lights.
I changed my boot lights to led bulbs erlier but as I changed the left bulb all interior bulbs went out. First thing I tryed was chanfing bulbs back to standard bulbs didnt work so then I did a full fuze check but found none blown. Any more things I coud try? Im sumped.
Have you checked fuse 16 in the fuse box at drivers side dash. I blew this one putting led boot lights in about an hour ago.
Yep cheacked that one. Wad first fuze I tried.
This happened on mine too, it was the fuse, just make sure you check the right one!
Ive checked 100% of fuses.
there is nothing else it could be, unless you have somehow fried the ECU, but I presume everything else is still working?
Yea car runs climatronic works etc.
I had exactly the same happen was the fuse. Remember when you look at the fuse box diagram so its the right way up its backwards.
Do you have headlight washers? Check the fuse for that as it caused mine to go aswell
No no headlight washes. Im a bit mithed here its no fuze took ever fuze out and checked all of them. I did notice there was a capicitor on the boot lights it this went would this affect owt?
Went and booked car in at skoda see if they can sort it seem as its under warenty. Placed the origonal bulbs back in so they can accuse me of doing it with led bulbs.
Yeh.... that will fool them lol, quick look on here and its good by lol.
All well. Worst is I have a bill for the work lol.
