Rear anti roll bar....further thoughts
i'm a bit puzzled about the rear ARB, how does it make a difference if the rear wheels are connected anyway through a solid axel. Isn't and ARB designed for independent suspensions? can someone explain please?
Edited by Bertie90
  • Replies 53
  • Views 10.8k
  • Really useful information, thanks guys! I ended up going with the Whiteline BWR19Z. Easy to install, good value for money and what a difference to the handling, just point the car to where you want it
  • Moist Von Lipwig
    Moist Von Lipwig
    Whiteline certainly makes a difference (I have it on the middle setting). To my knowledge the Jabba bar does not fit the mk2 vRS unless you have a modified exhaust
  • Moist Von Lipwig is correct regarding the Jabbasport bar. It fits with a Miltek Cat back, but not the stock cat back exhaust. I agree that the stiffer the spring/damper setup, the less effective the
A thread in the Octavia mk3 section might interest you.
http://briskoda.net/forums/topic/476157-torsion-beam-rear-end-estate-handling
Regardless of what might be said the rear ARB can change how the rear suspension feels as people who fit them might testify.
It might be an improvement, people certainly say it is.  Springs, dampers and tyres dependent though, and the ARB fitted.
Personally i preferred a Mk2 vRS hatch without rather than with, but i like roll in a car when driving spirited on real roads with cambers, potholes etc.
so the torsion bar has "some" movement apparently.
Reduces body roll apparently, Not sure about the hatch back but I own the estate/combi and the back end likes to go the opposite way. Lowering 40mm and adding the ARB seems to have tightened it up a little.
