Head gasket gone but no over heating or water in the oil
Hi I've just put my Vrs into have the cambelt at water pump done , it's been losing water for around a month not much just cup fulls . I've been told my head gasket has an hole in it and its pressuring the water tank . But theys been no over heating or water in the oil and wet carpets , could this sound right ??
I had a car do this a few years ago. The head gasket failed between a water gallery and a piston.
The only symptom was a pressurised water tank when the engine was running, and slight water loss. I actually ran the car like this for over a year before getting rid of it.
Mine did exactly the same last year no normal symtoms just looseing water
Is it not normal to have a pressurised water tank when the engine is running?
Mine has been doing this since October still doing it light come on every week just top it up but if I boot it then it comes on 5 mins after havnt got round to changing it yet due to this **** snow
Yes, but only to a max of 15psi or so.
When it happened to me, if I removed the cap to the expansion bottle when the engine was running, the coolant would immediately bubble up and spew out of the expansion bottle.
Some correct me if I am wrong but I'm pretty sure all vehicles do that when hot ?
Or are you talking about all the time even from cold in which case would make more sense I guess.
Yes, even if you took the cap off with the engine running and coolant cold, it would still spew out.
Mines grand when cold, never opened it when warm (afraid too haha) would that suggest mine is fine? My light comes on over a period of about 5-6weeks maybe more
Edited by wilsy7
Possibly, or just in very early stages of failure, or it's leaking from somewhere else?
Yeh I've checked but can't see anything, its such a small lose if its leaking from somewhere its gonna be hard to spot!
its still in the garage ,they phoned me today and said it had blown on clinder 3 its been skimmed and to the costly some of 95o all in inc the water pump cambelt , i wont get it back until next tuesday so he's had it 8 days think im been mugged off , lol but they are vw specialist , he also said it had been done before but not right as it didnt have a genuine gaskett ,any body know of a guy goes by the name of sonic vrs or sounds like this id really like to talk to him as he had this skoda from new and just wanted to find out if he'd had it on but doubt it as it has full skoda service history pmsl sooo mad ... keep you posted
You do realise that ALL garages are obligated to confirm the work before proceeding, if you ask them to quote before doing any work.
If they have done this and just writing a blank cheque with you then you probably are within reason to question this and bring up with the citizens advice bureau for further help.
Here is one link may be useful (simply found by searching garage charges lol)
http://www.bis.gov.u...s/file28053.pdf
Remember:
the law says that any services you buy must be:
carried out with reasonable care
and skill;
carried out within a reasonable
time at a reasonable charge (if
no charge is agreed in advance);
and that any goods supplied must
be of satisfactory quality.
If you told them you wanted to know the details and estimate of cost BEFORE they proceeded (which is only sensible) then they have NO right to just do the work whatever they want for work they say needs done
you can use the search bar to search members too
