TURBO!
Well, i blew my turbo shaft to pieces last night luckily the acutally seals remained intact.. Got myself a GTTDi 150bhp turbo off the Golf ARL engine for a decent price as i was told they fit, what do i need to do to fit this turbo to make it fit or is it bolt on ? Also will it need another remap with the FMIC and bigger turbo ? cheers
It`ll need "clocking" to go on, which is a simple process of loosening some nuts and rotating the housing. I`v not done it myself but i`m sure there is a guide somewhere. It`ll work as is, but to gain the extra power it`d need the map adjusting.
cheers buddy, yeah that was it, clocking.. pretty simple to do though i've heard, and what should be an approximate gain from them mod's, its already remapped and exhaust system inclu decat, so with the new turbo and FMIC it should be a bit better?
What can this turbo be remapped upto or is it similar figures to a KKK?
Right gttdi ones were garret?
Untill u get the map tweeked for the bigger turbo u wont see any gains.. maybe a bit more right at the top end..
Without adjusting the map u will get slower acceleration because the turbo is bigger so will take longer to "spool up".
So it will feel slower untill u sort the map ;)
+ Clocking the turbo is just loosening the 10mm bolts that go round the edge.. spinning it 90º (or fitting it and spinning till it looks right).. job done
.. double post
8mm I believe.
Well I'm getting it remapped again hopefully as soon as turbo is fitted so what figures am I looking at ? any rough estimates?
190bhp maybe?
Id have said around 190bhp.
190 safely or 195 pushing it to the limit
Ah so little more than a KKK not to bad.
Its not just the type of turbo kkk or garrett
Pd130 is a gt1749va
Pd150 is a gt1749vb
Complete different spec
