HELP - Locking wheel nut key snapped inside
Changing my wheels today and halfway through my locking wheel key has snapped inside - next door have a octavia but the key is a different star shape - Autocare said it will cost £50 to remove all 4
Any advice appreciated
Tap a a socket over the top of it best option
The newer ‘EVO’ bolts are IMO crap, which is why I changed mine to the earlier ‘ABC” spline type.
Take the car along to the dealer and they will have a master set of removal tools, my dealer let me use them FOC (I did buy a set of the older splined bolts at the same time)
Or if u can wait and have time the above.
Edited by ambrosevonpose
Now why did vag change some thing that worked absolutly fine. Haha
Grrr what a pain in the tits!! Especially on a sunday too. grrr.
You can buy a tool for removing bolts like that from machinemart, only a about £15 IIRC.
Done this before to remove a set from a C5 worked perfectly then replaced them. Id say needs to be a decent socket very strong like snap on etc.
Also a pretty thin walled socket, as it is very easy to butcher the alloy if you are not careful as there is not a great deal of room around the locking bolts.
i snapped one of those on my old car and bought a new socket from haldfords for about £12 not sure if they still do them.
Unless you have a set of trick alloys i really dont see the point in locking wheel nuts now, there just a pain in the arse. Its not 1980... everything and its dog has alloy wheels these days.
Good luck
They're a bit crap and you need a lot of torque in an impact wrench for them to work.
Mines snapped on my last car a superb took to dealer they took them off I replaced with bolts locking nuts are pain in th a... When I bought my vrs first thing I did was get rid and replace with bolt and new bolt covers.
OEM locking bolts can be removed by most tyre places. Find one you trust and they'll normally just hammer on a big socket to get it off.
Aftermarket bolts have features to stop that.
I've done the "hammer-a-socket-over-the-top" thing before to remove a damaged locking bolt, worked fine but destroys not only the bolt but also your socket in my experience. Having said that not much $ to replace and it allows you to get your frustrations out on the bolt!
Hammer time!
Took the car to a skoda dealer today and they broke there master socket try to remove it - then they said they couldn't remove the bolt as it has been put on with an air gun - at least i got my car washed and hoovered by them :giggle:
They've changed them (seeing the picture now). The ones my car came with were like big spline sockets. That looks more like a McGard bolt. I've got them on now and I've knackered it before. Easy done if you don't seat it properly. I had to order another from Germany.
can you not just leave them off that's what i done today on my superb and just left them in the boot too much hassle when at night and trying to get them off
Taking it to a local garage who are going to tac weld a bolt on then remove the locking nuts - After that I will just use standard bolts - Lucky this happened on my drive rather than on the motorway or somewhere remote
  • 5 months later...
Did you ever get this sorted as i have the same problem..... :wall:
