main brake lights not working!
my brake lights are not working the center one is. changed bulbs, checked fuses wiring in the boot looks ok - what next?
Brake light switch above brake pedal ??
Not if the centre one works.
Course it can be.
Course it can be.
Do explain
Explain how it can't be first.?
Seriously? One brake light switch with one wire. If the centre brake light works then how can it be the switch.
all other lights ok ??
is the prong in the holder touching the bottom of the bulb?
Because it isn't just one wire to and from the switch. SRS?
Changed the bulb holder/cluster on on side and made sure the terminals are all clean.
Tell me about this switch - the right bulb went first them the left if that makes a difference.
Edited by razoredge
Ok changed the brake pedal switch still not working.
if you have a multimeter get someone to press brake pedal while u check voltage etc.... do all other lights work fine alone? and together ? may be a bad earth?
