wheel bearings
Just had front wheel bearing replaced anyone else had this problem only done 2500 miles
Have you got standard wheels and tyres---a friend with a passat has oversize tyres and he had this problem--otherwise can only surmise a lack of grease at manufacture---what did the garage say?
Have not had the problem, but it sounds like a faulty bearing. Once replaced, the problem should be solved.
Haven't had it on a Skoda but had it on an X Trail. As Agerbundsen said, it was a faulty bearing. You shouldn't have any more trouble.
Had it on a new Ford - after 100 miles front o/s wheel seized and roasted the brakes due to absolutely no grease in the wheel bearing when assembled.
58k on mine and all bearings perfect.
  • 1 year later...
I've just had mine done, only one on the front, 22,000 miles and 4 years old.. Cost a lot too, bit annoyed.
