skoda octavia multi faults
a work collegue has a 2007 octavia ii. here is the fault code list:
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
Shop #: WSC 35115 000 1048576
VCID: 356B50705C5A696
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 80380 km
Temperature: 9.0°C
Voltage: 12.30 V
Voltage: 12.10 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 73430 790 00000
VCID: 3F8732586E66A36
3 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
00283 - ABS Wheel Speed Sensor; Front Left (G47)
now we have also had a weird fault where it would not start, but then would after turning off the ignition then waiting, then it will start. this would then throw loads of comms errors into the list:
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBDS21Z572163665 Mileage: 80390km/49952miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LB HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9251
Revision: --H07--- Serial number: SKZ7Z0G4202364
Coding: 0000071
Shop #: WSC 28061 210 64639
VCID: 6AD1B30C4564F6E
No fault code found.
Readiness: 0 0 0 0 1
Coding: 0017025
3 Faults Found:
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1Z0 820 047 K HW: 1Z0 820 047 K
Component: Climatic PQ35 140 0909
Revision: 00140009 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7F46487A7EBF6
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
01314 - Engine Control Module
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004909149
Coding: 00880F030004140000110D000000000000087B075C0000
VCID: 6BDFB6084A9EEF6
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 270407 022 0601
Coding: 00055223
Shop #: WSC 73430
5 Faults Found:
01516 - Terminal 30; Left
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 235
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 5.00 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 235
Mileage: 80327 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.70 V
ON
ON
OFF
OFF
OFF
00154 - Windshield Wiper Motor; Passenger Side (V217)
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 5.00 V
OFF
OFF
OFF
OFF
OFF
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 5.00 V
OFF
OFF
OFF
OFF
OFF
00926 - Terminal 30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 235
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 5.70 V
OFF
OFF
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD17LRGZ
Coding: 0020788
VCID: 3D7B4850646AB16
1 Fault Found:
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AK HW: 1K0 953 549 AK
Component: J0527 036 0070
Coding: 0000022
VCID: 7BFF86483AFE7F6
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 902 D HW: 1Z0 920 902 D
Component: KOMBIINSTRUMENT VD1 1620
Revision: V1620056 Serial number: SKZ7Z0G4202364
Coding: 0003401
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 235
Mileage: 80327 km
Time Indication: 0
Date: 2000.00.00
Time: 00:06:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 80327 km
Time Indication: 0
Date: 2000.00.00
Time: 10:30:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 80327 km
Time Indication: 0
Date: 2000.00.00
Time: 10:31:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 235
Mileage: 80327 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:08
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 170507F2000802
Coding: 3D0F034007001303
VCID: 2F676218BE06536
2 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 235
Mileage: 80327 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 80327 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:13
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1620
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000564
VCID: 387559444B4894E
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
4 Faults Found:
Freeze Frame:
Mileage: 80320 km
Temperature: 9.0°C
Voltage: 12.60 V
Voltage: 12.40 V
000 - -
Freeze Frame:
00625 - Vehicle Speed Signal
Freeze Frame:
Mileage: 80320 km
Temperature: 12.0°C
Voltage: 12.30 V
Voltage: 12.10 V
Freeze Frame:
Mileage: 80320 km
Temperature: 13.0°C
Voltage: 12.70 V
Voltage: 12.50 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CN
Component: KSG 0401
Coding: 81D002003F098505095B010004CC
VCID: 7EF98F5C29EC6AE
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00668 - Supply Voltage Terminal 30
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000564
VCID: 39735C4070428D6
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 020 0041
Revision: 00020000 Serial number: SKZ7Z3I0152329
Coding: 0010400
VCID: 2E597F1CB90C5AE
5 Faults Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
01042 - Control Module; Not Coded
000 - -
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
013 - Check DTC Memory - Intermittent
End ---------------------------------------------------------------------
Loads of Lower limit exceeded faults.
What state is the Battery in?
so its been to a main stealer, before i had a look at it, and they started just replacing sensors willy nilly, and ran up a bill of £740. it still has the abs sensor faults, even though the stealer replaced the two rear ones, and the pas doesnt work, even though they replaced the angle sensor.
A lot of those faults look old.
Have you tried clearing them all and seeing which ones come back.
that looks like a battery issue.
the battery seems ok, though it did start doing the abs/esp faults when the snow happened about three weeks ago. i told my friend to disconnect the battery to see if it would clear the abs fault, it didnt, instead it brought on the pas light (yellow) and had limited pas. after the stealer replaced the angle sensor it now has no pas at low speed. ive tried setting the angle sensor up using the basic settings procedure, this doesnt seem to work, as the angle in the measure block is 0.0' not -1.5 to +1.5 as described. so anyway i tried the steering limit setting and no joy. no pas and when the steering wheel is turned no angle readings in vcds.
if i clear them most of it goes, the above list was what was in the ecu after the main stealer had spent a week fidiling. most of it goes if i clear all dtc's, apart from the abs and pas stuff, but is it wont start it throws a load of comm errors up.
Edited by cypher007
If you're getting faults on 3 out of 4 abs sensors it would suggest a wiring problem, perhaps close to the abs controller or perhaps a problem with the controller. Does the wiring and plug around the abs unit all look OK, no sign of moisture/corrosion?
If the steering angle sensor has been replaced and is still throwing errors again could it be a wiring issue?
does the angle sensor go back to the abs ecu?
Edited by cypher007
I don't think so, but I couldn't say for definite whether it does or not.
voltage drop test batt.
I would start by looking at power/battery first personally, it seems to be a common cause of multiple fault codes
Ruling out the Battery is a good idea......perhaps measure the resting voltage of the battery with a digital voltmeter, and repeat the test while the engine is cranking, and see what figures it's producing.
batteries ok.
how do you know that, because you fitted one last year/month yesterday? Or did you have it tested, today?
