Removing Whiteline RARB off my car - any guides?
anyone got any guides for this?
or any pointers, need to take it off my car tomorrow
got axle stands and big jack and tools :)
big hammer :D
Get the arse of the car in the air first. Remove the bar at the "S" droplinks first - both sides. Then undo the clamps holding the bar into the beam and remove from car. Once that's done, unbolt the big bolt holding the "S" droplink into the bottom of the suspension damper. Make sure this is mega tight when you tighten back up afterwards.
This is a very basic "how to" but it is very easy once you get under the car :)
Chris
thanks :_)
can i do this without taking the wheels off?
got this pic of my car
You'll need to replace the bolts on the lower shock mount with the originals, The Whiteline comes with longer bolts to accommodate the droplinks!
thanks for confirming this
dont have the old bolts doh!
might pass on this now
Bolt
In true VAG style, nut not included. The part number for it is also there.
Hey. Yeah you don't need the wheels off to remove this. Does make things easier though. Don't know why you'd take that off though.
Chris
Just in TPS now :)
Just in TPS now :)
Then pm once you sorted everything mate :)
Thanks for your help guys.
Took me about 30 min in the end.
Dav is collecting this evening
