Fitting oil pressure gauge
Help needed, fitting pressure gauge but not sure when sensor needs to screw into, are there any pictures out there showing the area or hole it needs to be fitted in to. Electrical part is ok just struggling with mechanical part...
Sent from my iPad using Tapatalk HD
There's a useful bung you can use on top of the oil filter housing - number 10:
That's a great help, just need to locate it in the engine bay, guessing its towards the front. And like most things a bitch to get at !
Yep right at the front under the intake manifold and small plastic engine cover. Not that bad to get to, though I recall I installed my oil temp sensor there mostly by feel :)
Will be attacking it this weekend 3 pro sport gauges to be fitted. I may be back for more help and advice.
Thanks again
4mm allen key i think you need to get it out
Not fitted them yet, but took a quick look down that area. Would I be right in thinking the blanking screw as a hex/Allen key type fitting in the top and very shinny.
4mm I must be looking an wrong part. The the one I was looking at looked more like 10mm. Fitting tomorrow so I will keep on looking
Can I fit the sender direct or do I need some sort of t piece or extension .
Just done it today mate. Was a 5mm allen key needed :-)
U can fit temp sensor straight to it.
Cheers for that fingers crossed I find it at least I know to attack it with 5 mm Allen key.
That's where I installed mine,easy to get into with all the sai system removed.
Mine was a pain to get off ended up getting it off with a hammer and screw driver :-)
Managed to fit boost gauge and voltmeter but time beat me on oil pressure gauge and the fact not 100% sure which screw and its a total ass to get at. Leave it for a warmer day
If you still have all secondary air system in place it will be alot harder. With mine removed it was straight forward. Just ordered 3 Prosport gauges myself. Look forward to fitting them next weekend.
No not removed yet. The pro sports look good I went for white/green. White in day time green when I put lights on. The green is a bit bright tho.
Pics?
Will do at weekend
  • 2 months later...
Pics?
+1
  • 1 year later...
That spare hole for extra sensor is also M10x1 threaded ?????
Because i have sensor with 1.8"-27 NPT thread !!!!
Thanx for advice ...
