I think my central locking has reprogrammed itself. Help.
My central locking only unlocks the driver's door on the fob. In all other respects it works fine. All doors lock with fob and the buttons on the drivers door work. Reading the manual it seems that this may have been reprogrammed by me pressing the fob too much or somthing. Anyone know if this is the case and if there is an easy fix? I've tried using the key manually, which works but doesn't reset it.
Much appreciated.
Do the rest unlock with a 2nd press of the fob?
I think that's an available setting via VCDS but I don't know if it can be programmed using the fob or not.
No amount of pressing the fob unlocks the others, I'm afraid. You can hear that the pump(?) is only trying to unlock the drivers door, which led me to believe the others had become disconnected, until I got in the car and tried the buttons on the driver's door, which worked it fine. Because of this audible lack of effort from the other doors when using the fob, I'm fairly convinced it's a setting that's been altered rather than a malfunction. I am, of course, guessing!
