Spax Super Sport fitting...
Hopefully just bought a Spax Supersport Suspension Kit from a member on here..
Basically its shocks and springs...what else would you advise me to replace why I have the car apart?
I thinks new top mounts and top mount bearings are a must??
Anythink else and where should I get the parts?
Thanks in advance
And also do I need shorter droplinks?
I used new top mounts, top mount bearings and bump stops.
Drop links I'm not sure as it depends on the position of the bracket, they're only a tenner for focus ones so you could get them on hand.
I can't quite remember where mine came from but it was vw part shop or vw parts or something like that. They were a fair bit cheaper than TPS.
Thanks mate
I found out earlier that you won't need shorter drop links for that suspension, the brackets are in a position to fit the standard ones
Nice one mate :)
Got a link for where you'd buy these brand new? I can't seem to find anything.
They have some on the dpm website but there only 35 mm drop, can't find the 55 mm drop ones.
Unless the 55 mm drop is for non vrs models which would make the drop 35 mm on vrs.
But I could be wrong?
Actually I think they might be different
http://www.dpmperfor...100-p-6969.html
When they arrive i will post the part number to see if there the same as the ones on the dpm site...if you go in the parts for sale you will see what they looked like on the guys car :)
I dont believe they sell the 55mm set up any more, they are for the vRS model and go quite low
I've found some of their 55mm springs but they could be for a non VRS model as VRS is 20mm lower as standard IIRC?
