Washer fluid leak
The first problem with my car and it appears to be a washer fluid leak from the front nearside. Topped up the fluid to hear it start flowing just infront on the n/s wheel. It is under warranty so im not stressing, but has anyone else had this? Without taking the wheel lining off to have a proper look im guessing a pipe has popped from the nearside headlight washer. Anyone?
Yes, I had exactly the same, but RHS. As you suggest, headlight washer pipe disconnect.
Ray
Cheers Ray, did you sort it yourself or go main dealer? Don't fancy wasting half a day if its a five minute job.
It was under warranty at the time. Took about half an hour IIRC.
Ray
