Is this G60 flywheel vr6 clutch any good for a mk1 octy vrs
I have had dealings with techniclutch i recently purchased this i ordered it on a friday evening and it came on the following tuesday
http://www.ebay.co.u...984.m1438.l2649
The only difference between the kit you posted and mine is the make of the clutch sachs and valeo, the bolts and flywheel are exactly the same
its a well made copy of the g60 flywheel i couldent see any floors it was well balanced and makes no unwanted noises or feelings through the pedal when you change gear.
mine has now been fitted for a little over a week and ive done around 300 miles with no issues whatsoever
the car feels much more responsive and my mpg has gone up bonus !
there are many bad reviews on techniclutch but there are more good reviews so i took the gamble and it paid off
i paid £135 for the full clutch kit and the flywheel bargain !
Ok cool thanks for the advice will treat myself to one then :)
fingers crossed it all works out for you it makes a big difference to the standard Dmf :)
Techniclutch have a terrible namewhich is mainly because their "uprated" stuff is just painted red rather than being actually uprated.
As I said in the other thread their branded stuff should be fine
good news steven89!
yes frisco is right, a lot of stuff about them painting stock stuff, not a company i would choose to deal with, funnily enough, another mate of mine on here (an established member too, so i trust his opinion) fitted a tecniclutch kit, and is now having issues...
Ok then might have to have a rethink then any other suggestions where to buy from
Oet how's that miltek coming on have u got it off yet and any pics
eurocarparts do a genuine sachs kit iirc, have the part number somewhere..
also can order the parts from vag/tps
That's cool got a tps near me has anyone got part numbers do they do g60 flywheel as well
Thanks the heads up rwbaldwin won't touch them with a barge pole now
been rained off due to the weather, and man flu!
its my first job to do as soon as it stops raining, will keep you posted:>
Ok thanks oet
How about their standard branded stuff? Surely a Luk clutch is a Luk clutch? Mine is nearing 150k on the original clutch and the bite is getting a bit high and a stage 1 map is on the horizon!
Yeah that the way I look at it. They are a front for a fairly big distributor and they have no problems actually supplying the stuff so if it's a branded part it should be fine
good news steven89!
Yep that member is me.............. :sweat:
And yes I am having trouble with clutch judder. Going against my own normal high standards I bowed down to getting a uprated clutch and G60 SMF, from those guys(money tight at the time). Less than 6 months later it is juddering and i can hardly pull away without dipping clutch and re applying. I first thought Dogbone mount or even gearbox mount but replaced those.
As I am going for a LSD and maybe get a spare box to fit up i will bite bullet and replace before it goes bang.
But be warned folks,
I would imagine the OEM stuff they sell is ok as not made by them but anyone selling carp goods , you have to wonder on what you are getting for your hard earned dosh.
Most folks will only replace clutch and Flywheel once so pay wisely and don't end up needing to do it again on a cheap purchase on rubbish like I did.
P.S any one have a spare box or LSD going, dosh waiting...
Have to agree buy proper or buy twice !!
Bowders might have a spare box possible wil let you know next week if it comes off ;-)
Thanks guys for all the advice will be going to either tps or euro parts and see if they can sort managed to find part numbers if anyone wants
VR6 clutch from here http://www.vwspares.co.uk/g3clutch.php bottom one at 110 quid
G60/GTi flywheel 028105269BX about 160 quid
Flywheel bolts N90206103 x 6 about 3 quid
Clutch bolts N10101001 x 6 about 3 quid
Bowders, which clutch kit was fitted?
cheers buddy let me know....
Yeah uprated with red paint
Has any one use darkside developments on eBay before
