Another example of battery not good enough?
At the weekend if wired up my 2nd battery to my vrs. The battery is a XS Power D3100 (110ah and max output in amps is 5000).
Normaly if the car was left for more than a few hours when starting it would try to turn over but nothing then try again and it would fire and run no problems. I left the car for 8hours in total that day and when turning the car over after fitting the 2nd battery it turned over so quick it was like the starter was plugged into the mains.
Think this is another example for the battery not being man enough for the job?
5000 amps!? Why do you need 5000 amps to power a 400 amp circuit?
Sent from my LT26i using Tapatalk 2
As the 2nd battery is for ICE installs I suspect that peak current output is to give headroom for a serious bass transient (know in ICE circles as a burp) in to achieve high peak db readings in a vehicle.
I'm an SQ man myself but some of the extreme db cars are amazing feats of construction / design with one aim.
Paul
Are you sure Ryan means a 2nd as in two batterys present Paul or does he mean 2nd as in this is the 2nd primary battery he has fitted? As he does make a reference to the starter circuit.
And Ryan are you sure it's 5000 amps and not 5000ma?
Usually in a large ICE install you have a split load / charge setup, so if the ICE is used a lot for demonstrations and competitions, with the engine off, you only run the 2nd dedicated ICE battery flat - the primary battery is always available to restart the car.
XS Power D3100 AGM Power Cell
This XS Power 12-Volt Deep Cycle Power Cell features a sealed absorbed glass mat (AGM) design and is perfect for 4000-5000 watt car audio sound systems. The D3100 can be used as a replacement for your vehicles standard battery or as an additional battery to provide the extra power needed for a high performance aftermarket system. It's leak-proof design and no external vents allow this power cell to fit in most factory battery locations with no hazardous leaks.
XS Power's D3100 Power Cell puts out 1360 cranking amps with a maximum output of 5000 amps, this is plenty of power to crank even the highest performing engines. This battery will resist extreme heat conditions and vibrations and is 100% sealed in a reinforced ABS plastic case. M6 Terminal hardware is included for your installation convenience.
Battery Features
  • 12-Volt Deep Cycle AGM Power Cell
  • Sealed absorbed glass mat (AGM) design
  • Can be used as a replacement for your vehicles standard battery
  • Can also be used as an additional battery to power your high-performance sound system
  • Perfect for 4000W - 5000W car audio stereo systems
  • Leak-Proof, non-hazardous design
  • Stores energy so you don't need a capacitor for your system
  • No external vents allow this battery to be mounted anywhere with no leaks
  • Reinforced ABS plastic case
  • Conforms to Group 31 BCI standards
  • Will fit many large truck, bus, and motor coach applications
  • Resists extreme vibrations for ultimate performance
  • Fits in almost any factory battery location
  • Enough power to crank the highest performance engines
  • Extreme heat resistance
  • 100% Sealed and maintenance free
  • M6 Terminal hardware included
  • XS Power 580 SAE short post terminal adapters available
  • Authorized Internet Dealer
  • 3-year Manufacturer's warranty
Battery Specifications
  • Cranking Amps: 1360
  • Maximum Output: 5000 Amps
  • Amp Hours: 110
  • Weight: 77 lbs
  • Dimensions: 13”D x 6-15/16”W x 8-7/16”H
So not 5000 but 1360CCA, when a large Exide EA852 maintenance free car battery already has 85Ah / 800CCA, and a smaller one 77Ah EA770 has 760CCA.
You need true ~350CCA to start the car. For ICE, XSPower it may be a good battery, but an overkill if you just want the standard car
OE batteries are doing under 500CCA when new/fully charged and that's a bit on the low side, especially a few years and an incomplete charge down the line.
100%. 5000ma is what you get from a 18650 battery for a torch etc lol
I dont think anyone would buy one to use as a normal starter battery.....if you did you have more money than sence lol
the XS battery is in the boot in addition to the standard battery.
A battery like that is needed with 7000wrms of amplification in the car, as GTI Jazz Blue said, its for SPL application. I know most people here aren't into audio but I didnt expect those reactions lol
