Carparts4less pagid discs help.
Right guys, coming to purchase some new discs and pads for my vrs but stuck as there is to options for the front and two for the tears, can anyone point me into which ones I need? I can the the difference is the thickness of the disc and a few other variables.. Thanks.
Fronts are 288mm ones so the bottom ones and I will get you the rears as I've just done mine off here. Do you want the pagid pad part numbers? Also use save10 or save discount code
No discount codes available as sale is on!
Fronts are 288mm vented discs
Rears are 232mm solid discs
Didn't realise they had a sale on. I should of waited a few weeks to buy mine! You beat me to it with the rear sizes
Thanks guys... When the sale ends will I be able to use the save10 code or do you think it will be better to buy them in the sale? ... Yeh the part numbers would be great thanks
Pagid fronts 101441398 rear 101440328. I paid £83.99 for pagid front and rear pads and the eicher discs with next day delivery which was £3.99 so compare prices. Price it up and knock 10% off and see how much it is. If you struggle deciding on which pads ours don't have wear sensors
Save10 code is rubbish!
Better using brisk25 (25% off)
Or ukmkiv25 or ukmk425 (25% off) - cant remember which one it is
The brisk code etc is for euro car parts which is dearer than carparts4less even with 25% off! Save10 is for carparts4less
The Brisk25 doesn't work on car parts for less :( but with the same parts as Kylevrs and using the CP10LESS (£10 off when spending over £25) it works out as £78.92 so still a bit of a saving over the save10 code
Ah right never heard of carparts4less
It's ECP in disguise, prices are lower but they only do delivery afaik.
can anyone get the discount code work on carparts4less?
Don't think it will work this weekend due to the discount they are already offering.
im talking about the one listed on the site, CP15LESS etc.
SAVE10 is working.
Edited by coiner
SAVE10 is working.
You need to spend £100 for the CP15LESS one to work mate.
