It all went wrong on my drive home
Hello,
Drove home today after a day out and the car was suddenly running lumpy at idle, the epc light came on, it went into limp mode, the traction control light came on and the engine management light came on. I also lost proper use of my brakes on two occasions, the pedal was rock hard and I could barely brake. Any help would be appreciated! Just got the codes read:
VCDS-Lite Version: Release 1.1
Monday, 01 April 2013, 20:05:08.
Chassis Type: 1U - Skoda Octavia I
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,56,76
Address 01: Engine Labels: 06A-906-032-AUM.LBL
Controller: 06A 906 032 HL
Component: 1.8L R4/5VT G 0001
Coding: 11530
Shop #: WSC 31480
VCID: 6F9150BF3E93
TMBFL21U738675350 SKZ7Z0B1497195
4 Faults Found:
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - - Intermittent
17950 - Shareware Version. To Decode all DTCs
P1542 - 35-10 - Please Register/Activate - Intermittent
17972 - Shareware Version. To Decode all DTCs
P1564 - 35-10 - Please Register/Activate - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01M-927-733.LBL
Controller: 01M 927 733 LL
Component: AG4 Getriebe 01M 4956
Coding: 00000
Shop #: WSC 00000
VCID: 857D92178C2F
No fault code found.
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.LBL
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480
VCID: 321799CBED21
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
P1171 is throttle motor position sensor 2
P1542 is throttle motor position sensor 1
P1564 is Throttle control unit - voltage low during basic setting
P1297 is Turbocharger (TC)/throttle valve, hose connection - pressure loss
The first 3 codes relate to the throttle body, however a voltage problem could cause it as well. I'd check the fuse box on top of the battery for any signs of it overheating as it is a common problem on the MK1 and then proceed to check the underbonnet wiring and connections.
plus 1 for the melting fuse box causes alsorts of problems
This is the best I could do in the dark but looks ok to me - is this the right place?
Right place - check all that all the nuts are nipped up.
Also check your earth points, Bad earth can cause this type of random faults.
Cheers, will check my nuts are tight this evening! Regarding earth points, do I just follow the black wire from the battery or are there any others in particular?
