FABIA PROBLEM HELP?
Hi guys,
im starting to have weird little problems. well ill start off, 2 days ago i got a sub fitted in the car, and yesterday i noticed my lights starting to flicker, then today my power steering warning lights came on then off after a while, then battery (while engine on) is making stupid robotic noise.
what do you think is the problem?
someone said to me it could be the battery not strong enough after having a sub fitted.
PS: i changed my battery 3months ago. so i dont know whats going on
thanks for the replies !!
Firstly...who fitted the sub?
Disconnect it, do you still have the same problem?
Have you earthed the sub to the same place as the rear lights?
If so change it to one of the seatbelt mounts.
a friend fitted it, he does a good job so it should be fine. and yeah i think the sub is making my battery to struggle. what do you think i should do?
ill see if it helps
thanks!
fit a power cap
