Vagcom question...
Ihave a question do you have a lot of keys with the fob,,,,,Reason i ask my mate has a nissan almera had same problem would not start nats kicking in Immobiliser which is there own system fuel pump was working etc put on vagcom said no faults, googled and the most common reply was the keys are interfering with the signal tried spare key on its own and it works fine that was about 3 months ago,still going strong wont cost anything to try i know it sounds strange but it is absolutely true good luck buddie.
I've no other keys with fob sadly...
Further update and probably best to hang fire with the ecu for now (I think!)
By all acounts the loom from the ecu runs down and under the battery and is a common'ish fail
My neighbour buddy will get the wiring diagram on Monday and weather permitting will start looking for the problem that evening...
Fingers and everything else crossed, I will update next week and thanks for the replies, much appreciated
Hi. My EPC and EML lights do not come on when I turn on the ignition so if you find out why yours doesn't could you let me know ? Might help me sort mine.
Thanks/regards.
Rob
Edited by comfortablynumb
Have you checked the earth wires under the battery?
Sent from my GT-I9300 using Tapatalk 2
No. But I will. Thanks. (Is that suggestion for me or red devil or both ?)
The loom from one side of the ecu passes under the battery tray and that is where my neighbour thinks the issue is, either the earth or within the loom itself...
All going to plan he'll have a look tomorrow evening and I'll update hopefully with a smile back on my face!
Took longer than expected due to workload (not mine lol) but its fixed and up and running again...
Nipped wire next to the ecu was corroded, tapping into the harness for the lpg many moons ago likely to be the start of the issue
Thanks to everyone who offered suggestions and parts to try, I hope I can return the favour one day
Happy days
