Tow bar fitting
Any tips on fitting 1 to a mk1 vrs? Does the bumper need to come off etc
Yes as you need to replace the crashbar.
Here is mine on my TDI (under he watchful eye of the collie);
Unless you are fitting a swan-neck you will also need to make a nick in the underside of the bumper too:
The standard crashbar looks like this:
Cheers. I'll give it ago when weather gets better. Looks like a pain !
Bumper off, crash bar off,
fit towbar and wiring through gromit into car and then refit bumper,
fun bits wiring electrics up, finding out what does what etc, I fitted mine and used a bypass relay box so also had to run a power supply for it from fuse box at front of car behind headlight switch
Fitting is easy. 6 nuts to remove the old crash bar and 2 bolts per side (iirc) to secure the new crash bar.
Did the tow bar it's self in 30 mins inc cutting the bottom of the bumper lol. It's easy
So I've got the bumper off and old crash bar off. The tow bar doesn't line up to the studs the old crash bar fitted on. The tow bar also has 2 legs bolted on which slide in the 2 gaps in the car but again there is no where to bolt it up. Unless I was to drill in to the car! Any ideas
There's holes in the chassis rails, covered with seam sealer, poke it with a screw driver to find them
Sent from my GT-I9300 using Tapatalk 2
Found them cheers was all for giving up !!
No problem m8 had the same panic lol
This picture is a bit late now, but it might help other ppl in the future
Out of interest what make is your towbar ?
Towquipe.
I bought it off ebay (as it came with free delivery.....)
  • 2 years later...
Hi Guys, i know this is an old thread but ive bought a new old stock swan neck original skoda tow bar for my estate but because its old stock it doesnt come with any bolts to fit it, does anyone know the specs, mostly the length of the bolts i need to fit it? Many Thanks
have a look at the westfalia website - I'm sure my fitting instructions mentioned a length
  • 2 years later...
I've just purchased a towbar (and fitting) from Towsure... BUT despite the towbar arriving yesterday the fitters can't do until end of June - Towsure now use a subcontracted mobile fitting service. So I cancelled the fitting and I should be getting a refund - but so far no confirmation so I think another phone call is in order.  I'm glad I found this thread and I'll attempt to do it myself with a borrowed torque wrench.
Is there a thread for how to take the bumper off too? And any tips for connecting the wiring? I've got those clips to connect to existing wires.. and an audible monitor thingy in the kit.
  • 2 years later...
Took me 3 hours you need the wiring diagram , the Haynes one is complex I found . Someone up above said they did this in 30 mins , I do not believe them .
This should fill in the gaps for the bumper assuming you have a hatchback -
Summary of components of rear bumper
1 -  Cross member
On vehicles with trailer coupling, replaced with trailer coupling frame.
Removing:
–  Remove bumper (Pos. 6).
–  Unscrew nut (Pos. 2) and remove cross member.
Installation is carried out in the reverse order.
2 -  Nut, 20 Nm
3 -  Cover strip below tail light
4 -  1 Nm
5 -  Cover strip
q   Pressed on into the bumper clips (Pos. 6).
6 -  Bumpers
Removing:
–  Open tailgate.
–  Detach cover strip (Pos.).
–  Unscrew screws (Pos. 4), slide cover strip below the tail light (Pos. 3) in the direction of the centre of the vehicle and remove.
–  Disconnect bumper strip (Pos. 8).
–  Remove side trim panel in luggage compartment and unscrew screws (Pos. 10).
–  Pull out bumper to the rear.
hinweis.gif  Note
Before removing the bumper it is necessary to disconnect plug of park sensors (if present).
The installation occurs in reverse order.
7 -  Rear spoiler
q   Slightly pull off the luggage compartment trim panel for unscrewing.
q   For vehicles 08.00 ► integrated in the bumper.
8 -  Bumper strip
9 -  1 Nm
10 -  8 Nm
q   Accessible via the luggage compartment.
