2001 Fabia 1.4 for
Weird. I've had two comforts with disc brakes (including the mongrel which is a comfort TDI ultimately), but they were turbo diesels. Perhaps it is more to do with engine choice, so all the 1.4 MPI / 1.9 SDI get rear drums?
The daughter's is a 1.4 tdi so I suspect they throw on anything whatever's to hand on the lower specs unless the car is ordered with a particular spec. I think you could actually have ordered a classic with rear discs if you wanted it.
Will be discs all round. Only classic came with rear drums. :) Even comfort trim had the stock 232mm rear disc setup. :thumbup:
All Mk1 Fabia's came with drums except (to my knowledge) the PD100, vRS, 16v (100bhp) and 2.0 which had 232mm rear discs :)
Perhaps also to do with ABS.
Was ABS optional on some trim levels? I imagine you can't have ABS on a drum brake.
Re: abs flow fault, check the fusebox on top of the battery for loose or corroded fuses or terminals..
ABS definately optional on classic. I have rear drums and ABS but I would expect it only has sensors on the front.
Yup - a google search brought me back to this forum and to a thread from 2009 ish where this was described. I shall see if the fault has come back when I take official possession tomorrow evening. First job though is a tardis soaking, and full clay. See what that paint is like! :thumbup:
Just had a sudden thought that this car is the perfect donor for a 1.8T quattro project, but that will have to wait for another day.....
just say the word, I've got an a3 quattro donor car sat here waiting... I could make this happen.
Stop it! You are NOT helping! :D
