Rear bumper removal
my Octavia is a 2007, means a pre-facelift estate. It has at the lower end of the rear bumper all the way round from wheel to wheel a black plastic spoiler (as Skoda calls it). I managed to damage that one, how was lucky enough not to damage anything else... :whew:
It's cosmetic damage, but anyway..
I got a new one and thought it should be easy to fit. The screws at the lower end are easy of course, but where it meets the bumper (the painted one), it is cliped into it at every 10cm or so...just excuse my lousy English :blush: .
I struggle to get the spoiler detatched from the bumper and was wondering:
1. Is there a good trick as of how to get the spoilers clips out of the bumper without doing damage?
2. Does the bumper nee to be removed?
3. In that case, is there a description somewhere about how to remove the bumper ( I did a search, but without success)?
Thanks in advance!
Edited by jogo
Sorry for the stupid typing error. :wall: The car is a 2007 model. Have corrected it in the original post.
Hi Mike,
Thanks so much for that you took the time to provoide the information. Please excuse my ignorance, but I still don't really understand what is the best way get the said spoiler romoved from the bumper.
If I have to take the bumper of, it would be good to know where it is fixed to the car body so I do not have to pull everything apart on the inside that prevents me from seeing it.
On the Octavia I I once remove the rear bumper and found very simple, on this one I'm not so sure... :blush:
I have the Heynes manual, but this task might just be too basic for them to bother to descibe it..
Jogo
I watched my towbar being fitted and the guy removed the bumper (and the crash bar and lowered the exhaust etc ...).
I don't know if this will be any help but...
1. In the boot he pulled trim away from both rear light clusters and removed some screws to release the clusters. This exposed two rubber pin thingys in the top of the bumper previously concealed by the lights - he pulled out these riubber thingys.
2. He slid on his back to unbolt the fixings along the bottom edge of the bumper. He then removed the bolts holding the mud flaps and the bumper arch to the the underlying metal work.
I think he was then able to slide the bumper backwards and remove it from the car.
He did remove more boot trim but I think that was only necessary so as to access the wiring but I apologise if I've missed something out.
Chris
Haynes manual page 11.6 has description of removing the rear bumper.
Mike
You are right Mike, I see that now. I looked in the index of the book and it is not mentioned there (at least not as "Rear bumper"). I then flipped through the section "Bodywork and fittings" but must have overlooked it. Shame on me :blush: . Thanks for pointing me to it! :rock:
Jogo
Chris,
thanks for sharing that information. I'm not sure if I would have stood beside and looked at the operation if I would have been able to do such writeup!
I think I'm getting the picture now how it works.
Again, thanks for all help you provided.
Jogo
Edited by jogo
  • 13 years later...
Just a little more info about removing the rear bumper, based on my recent experience of doing just that on my 2009 pre-facelift Elegance 1.9 TDI PD hatchback.
You do indeed need to remove both rear light clusters so that you can remove two pieces of trim that are covering up two screws each side. These pieces of trim just snap into place.
I also removed both rear wheels - one at a time - to enable me to access the four bumper screws in each wheel arch.20260810_150943.jpg20260810_150943.jpg
You also need to remove enough of the boot's felt lining to expose two nuts on each side of the boot, that are attached to bolts mounted on the exterior of the vehicle (but hidden under another bit of trim that wraps around almost the entire bumper). See the attached photos of these bolts and nuts. I initially tried to unscrew these bolts from the outside but that can't be done. I'm afraid the photo of the two exterior bolts on the left hand side of the vehicle appears twice. I couldn't delete the duplicate.
Edited by roghol
Need to delete a duplicate photo.
