Using a Ezi bleed to change brake fluid.
Im going to replace my front brake discs & pads soon & as its nearly 2 years since the dealer changed my brake fluid i thought id change that at the same time,is a Ezi bleed ok to use? has anybody used one on a octy? Whats the best brake fluid to use?
I've used one many a time and never had one problem. Just make sure you dont over pressurise the container.
Day
I've used one for years. It can be a bugger to get to seal (I presume to the more worn seals on mine) but they work well. The bleeders that use vacuum are better though (and more expensive) car factories use them when they build the cars
2 litres of dot 4 should be enough shouldnt it?
Well,ive ordered one so hopefully will be changing my fluid in a couple of weeks.
I wouldn't do a fluid change without mine now.
As above just make sure you don't exceed the maximum recommended pressure and make sure you use the correct lid for the reservoir.
Phil
Yep, make sure you let plenty of air out of the spare tyre beforehand.
Sent from my HTC One X using Tapatalk 4 Beta
Ive got a old 10" mini spare wheel that im going to use. :thumbup:
