Installing an aftermarket stereo to vRS, what do I need?
Hi
I have just purchased an aftermarket stereo for my Octavia II vRS. I am aware that it will not fit perfectly into the dashboard, and have read various guides on how to remove the factory unit and install the new one, but I'm a little confused as to what I need in terms of a fascia kit.
Will this be sufficient - http://www.caraudiodirect.co.uk/con-ct24sk07-ct24sk07-facia-plate-for-skoda.html
Or do I need all the stuff found in this - http://www.caraudiodirect.co.uk/con-ct23sk01a-ct23sk01a-double-din-facia-plate-for-skoda.html
Or both?
Any advice would be appreciated, thanks.
i'd go to skoda and buy one from them.
Make sure you get the correct colour facia with it though.
Its more expensive from skoda but its a better fit.
You will also need to get some wiring adaptors. Choises of finding a switched live in the fuse box and running it to the ignition live on the headunit or buying one of these
http://www.caraudiodirect.co.uk/ctssk002-can-bus-steering-control-adaptor.html
you will also need one of these two for the aerial
http://www.caraudiodirect.co.uk/con-ct27aa14-ct27aa14-aerial-adapter-for-citroen-peugeot-skoda-vauxhall.html
http://www.caraudiodirect.co.uk/con-ct27aa15-ct27aa15-aerial-adapter-for-citroen-peugeot-skoda-vauxhall.html
