changeing rear pads ,55plate vrs
hi need a bit of info
going to change my rear pads .how do i change them are they easy to do?
what tools do i need?
thanks
thanks
Very easy job, you will need either a 12 or 13mm spanner and a Wind back tool, other than that jack it up and remove wheel
Radiotwo
Yeah pads-only should be very straight forward, you only enter a world of pain and suffering when you have to do the discs.
hardly, discs are very easy to change once pads are out
Why !
You only need a extra either 17 or 19mm spanner
I have never had problems changing discs
Radiotwo
Why !
Radiotwo
He's being specific to the Octavia VRS. I've never had trouble changing discs on any car I've had before but the rear discs on the VRS are a right pain in the arse to change due to lack of space to get at the bolts.
Why !
Radiotwo
Suuuure.
They have obviously not tried to get the carriers off on the rear of an Octy!
Not too bad if you have access to a lift, but a bit of a mare trying to do it on a jack.
Sent from my HTC One X using Tapatalk 4 Beta
