depo wingmirrorman projectors
  • Replies 59
  • Views 5.7k
  • devonutopia
    devonutopia
    You retrofit your original headlight adjusters into the Xenons from Depo.  They work in the same way.  If yours are bust, find a pair from a front end damaged car.  Probably find a smashed headilght s
  • XLBaconDoubleCheese
    XLBaconDoubleCheese
    Aye, agree with that!
    XLBaconDoubleCheese
Link don't work for me mate
http//dclamps.pl/en/shop/headlight/skoda-fabia-rs-right-headlight-xenon-336.html
Are you sure they're for a RHD car?
With them being from Poland I'd imagine they're LHD
Any photos of these on a car?
Managed to get hold of a pair!
I phoned up wingmirrorwomman direct and managed to get a set for £199.99 posted! Should be with me in the next few days.
just in case anyone wanted it there number is 0761 763 0808.
Edited by Alex_fabia
I shall be getting myself some also, thanks or posting :)
It says the number is not recognised btw mate
sorry it's 0161 763 0808
So I take it you need a set of aftermarket hids to go into these units?
Yeah, although there is a Kelvin scale which is very close to oem.  I have 4300K in mine, and they give off a good stock looking white light.  :thumbup:
Yep, some whatever K rating bulbs you want in D2S fitting with ballasts aswell and some adapters if you need them to use non D2S ballasts
Anyone got a photo of these!?
Yes I will need some adapters so I can use the ballast from my h7r hid kit.
Not sure whether to get 4.3k or 5k lamps? I want pure white with no tint of blue.
4300 are nearest to oem but have a slight yellow tinge to them. 5000 will be a little bluer but nt sure as I ran 4300k
I'd also add that I used to get some flickering of the bulbs till I put in the canbus cancellers. Although not needed at all they did stop the flickering till I crashed and wrote the vrs off!!
will probably get 5k then as I don't really want a yellow tinge. Sham about your car!
Mine were 4300k, were white light. Looked OEM
Turned up today!
4.3k lamps also arrived just waiting for the ds2 adapter cables.
All fitted,
Looks great mate, also really like your colour coded silver grille :)
cheers, sprayed it myself with a rattle can.
