Gally28's Fabia vRS
  • Replies 55
  • Views 6.8k
It does seems only to do it when cold, engine gets to normal temp can hardly hear it,
I'm running FK's and i can drop lower then that.. i still have 20mm to drop on the front and i can remove my helper springs.
The rear is maxxed out but with only 1 adjuster ring in. I can remove the other or remove the adjuster totally.
Both adjuster rings are right at the bottom off the thread pal
But you can still go lower.
How?
