throttle body cleaning
Hi all I'm not the most technically minded amongst us but have been looking fora thread which tells me where the throttle body is and how to clean it .please help a dumbo
Thank you very much got it off no problem next thing though should it be oily on the outlet side as that is mega dirty compared to the inlet
Edited by alex27
Going to have to wait for the experienced guys to wander in later... i've not ever done this either..
Cheers anyway much appreciated the link  :happy:  :happy:
The manifold side is where it gets gunked up the inlet side is normally pretty clean. Whatever you do not force the butterfly flap open as it will break. When I've done throttle body clean in the past I've left it plugged in & wedged the gas pedal down to clean around the edge of the flap.
Oh I've taken mine of and it moves but with some resistance but will defo watch what I'm doing cheers
Once cleaned you will need VCDS to reset it. Was it damaged before you decided to clean it?  Or was it just dirty?
I think it's just dirty as I've been getting some sluggish performance.I've recently changed coils dump valve and filter so this is my next try
Am I right in thinking that if you keep it plugged in during the clean you don't need to calibrate it?
It will adapt over a few driving cycles or you can use VCDS to do adaptation. If you unplug it it's important to turn the ignition on after reinstalling until the throttle body stops whistling, & then start up.
Edited by pauldazzle
as Paul said above, it will eventually set itself but VCDS does a good job, keep it plugged in should be OK.
Thanks for all the help guys much appreciated
