Skoda Roomster 1.2 HTC 51kw '98
Hi,
I have problem with my Skoda Roomster 1.2 HTC (3 cylinders) when engine is cold.
Engine is shaking everytime until reaching working temperature and it is no matter on petrol or GAS.
Sometimes it shaking so hard but often less.
Computer shows error: P0301 Code - Cylinder #1 Misfire
What I have done:
1. Replaced spark plugs in all cylinders
2. Exchanged coil packs (Coil pack from 1 cylinder with 2 cyliner coil pack)
3. Reset fault.
But no effect - engine still shaking. After one week fault appiers again
Then:
4. Metered pressure in cylinders - (pressure in all cylinders is 14 - OK)
5. Once again mixed coil packs between 1 and 3 cylinders.
No effect. Problem still present.
My car have runned 177.000km. and most on GAS.
Where the problem can be ?
Is it possible that problem is burned exhaust valve when
pressure in cylinders is OK ? (I have metered on cold engine)
Is it possible to problem in wires when hot engine runs OK and not shaking ?
When engine is cold and shaking i feel no so good smell from exhaust.
Thank You
