Car sounds like a hairdryer with fault light on.
Strange noise from the car, sounds like someone using a hair dryer also associated with cel lamp on and fault code, 17544 fuel trim bank 1 system too lean. Would a failing fuel pump create this kind of noise??
Or should i suspect something else, no loss of power or any other indications except noise and the cel lamp on. Any help appreciated
Can you get any videos up with the noise?
Is the noise there all the time? If only for a min or so when cold then it will be the SAI pump, very common.
