Torque settings for longer wheel bolts...?
fitted 20mm spacers on rear and 15mm on front of my 2011 fab i also needed to use longer wheel bolts 45mm thread length and just need to know what torque settings i need for these. cheers
Same as standard - length won't make any difference.
hi man thanks for the reply but im only getting myself a torque wrench now and never knew the settings i always used a normal wheel wrench but im worried now when im tightening these longer bolts that if i tighten them to much and they might snap, i think its because ive spacers in now that im a bit paranoid and think the bolts have to be as tight as possible. they are hub centric spacers btw.. :think:
Standard torque setting is 120nm.
Tights tight and too tights ****ed is something I explain to everyone. Tighten them with the standard wheel brace and you won't over tighten them and you will get them off if you have puncture
al
