DMF?
I suspect these syptoms are of a failing DMF just be good if any of you guys could confirm this for me?
Car is a 56plate 2.0tfsi vrs just hit 70k-
When car is in neutral and clutch is not depressed there is a tapping noise
When coming off the power in 6th there is significant vibration through the gear stick (and faintly through the jumbo box armrest)
Significant vibration under heavy acceleration.
cheers in advance for any feedback
while driving i can see and feel a little vibration on the armrest to .and the clutch os juddying when releasing without giving gas in all gears .  my car is a octi mk2 1.6 mpi
The vibration under heavy or hard acceleration is the biggest clue to a worn DMF.
If accelerating in too high gear and too low rpm makes the vibration worse to the point it begins to judder then this will confirm the DMF.
As far as I know the 1.6 MPI does not have a DMF. So your issues must be down to something else........contaminated/worn clutch, out of balance tyres etc.
i hope the car doesnt have the DMF !! ok i hope the vibration while driving is out of balance tyres . thanks
Edited by SKODA OCTAVIA
Mine's having DMF replaced at the moment - symptoms pretty much as described above. Thankfully replaced under warranty.
just replaced my DMF(and clutch), horrible tapping noise and vibration, least you haven't got the 4x4 and can do a SMF conversion, theres plenty of thread on here and well worth searching
  • 3 months later...
can someone confirm ? does my car has a dmf or  not 1.6 mpi BSE
not sure about your car having a DMF but the vibration under heavy load could also be a sigh of the drive shaft inner joint or intermediate bearing. Get under car and have a good feel/push/shove at the shafts and see if there is any excessive play. its difficult to say without actually feeling it myself. A good mechanic will tell you.
Could be gearbox or engine mountings?
The problem on Mine car is when releasing the clutch pedal it. is kludderiet 3-4 Times' on all shifts , shift 1 to 5 . But if i give a little bit gas exacktly before releasing the clutch pedal you Cannot feel something juddy. Dont know what it is But i think it is dmf
Yep sounds like a dmf mate, i had to replace mine, ended up going for the LOBA motorsport kit made a massive difference.
